I am finally boosted yea!!!!!!!!!!!!!!!!!1 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2006, 09:24 PM   #1 (permalink)
View klone1000's Photo Gallery
Whats up guys my 1992 toyota celica(5sfe) is finally boosting. I have a small turbo that I ordered from ebay for 200.00 new in the box. The wastegate is set to 8.7psi and when I am boosting it reads 7.3psi on the intake side. So I guess I am loosing about 2psi through the intercooler. The car feels like a feather being pushed around by air. Loving it man.
klone1000 is offline   Reply With Quote
Old 02-28-2006, 02:55 AM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Cool, I'm going to be moving to TruBoost Performance in Beaufort, SC, come by sometime if you want.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 02-28-2006, 10:27 AM   #3 (permalink)
View 92ceilca's Photo Gallery
Did you have a stock motor if so wha tkind 2.2ltr? or 1.6 or what did u have.... also ur msd do u have the wireing diagram for it becuase i actualy have a msd just dono how to hook it up so far and cant find the diagrahm
92ceilca is offline   Reply With Quote
Old 02-28-2006, 02:52 PM   #4 (permalink)
Noob :-)
View ST185's Photo Gallery
5SFE is 2.2L
93 ST185
ST185 is offline   Reply With Quote
Old 02-28-2006, 02:54 PM   #5 (permalink)
View A Diddy's Photo Gallery
congrats man, must be a great feeling!
A Diddy is offline   Reply With Quote
Old 02-28-2006, 10:19 PM   #6 (permalink)
Gen5
Yea exept no one told me what type of oil to use. I was using 5w20 pensoil and I added some oil enhanser(which made it thicker). Today when I crank up the car smoke was coming out the tail pipe. Then later cleared up once the car was warmed up so I thought nothing of it. So I went on a few boosting runs and everytime I boost there is smoke coming out of my pipe. Blue smoke. So i thought damn my seal in the turbo must have went. So I started back home and at 7psi my boot came off the intake. When I looked inside the boot oil was inside the intercooler pipe and that was what caused the boot to come off. Damn did not know that you cannot use heavy oil in a turbo setup. The car still boost but not without the blue smoke. Oh I forget to mention my safcII does not detect any knocking while in boost. The msd map must be doing its job. Guess I will be getting a new turbo. WHAT TYPE OF OIL ARE WE SUPPOSE TO USE WITH OUR 5SFTE
Old 02-28-2006, 10:26 PM   #7 (permalink)
This Is How I Preped The Turbo:::::::::::::::
First Installed Oil Feed Line [after Changing The Oil Of Course]
Poured Oil Inside Turbo Drain Hole
Installed Oil Drain Line
Took Wires Off Igniter And Crank The Engine For 1 Min
Connected Igniter
Started Car
Let Ran For 20 Min
Then Started Boosting
did I Do It Right.
Old 03-01-2006, 09:19 AM   #8 (permalink)
Aww man that realy sux sorry to hear about ur turbo.... if you get a new one would u be willing to sell the one that u just had? if so how much i have a friend that rebuilds them
Old 03-01-2006, 09:29 AM   #9 (permalink)
come to www.celispeed.com and ask that queston...I cant answer it but many othrs there can
Old 03-01-2006, 10:49 PM   #10 (permalink)
Yea Ill sell it for 100.00. Im gona try to change the oil to a lighter weight and see if that will help the oil flow first and add more crankshaft ventallation. If its still smoking Ill sell it to ya... Now a days its cheaper to buy another one... If thatone goes Im gona build a na engine... from stratch.
Old 03-02-2006, 10:00 AM   #11 (permalink)
Okay sounds good just keep me updated on wats going on with it and if u wanna sell for sure or not =)
Old 03-03-2006, 06:08 AM   #12 (permalink)
Celica Enthusiast
View DomGT's Photo Gallery
Great job man, soon you will be addicted to boost.
1996 Celica 1.8 Blk/Blk 25th Anniversary Edition (#994) 134k miles
One of the many pics of my true baby:
http://www.i3igd.com/auto/data/media/62/99sig4small.JPG
DomGT is offline   Reply With Quote
Old 03-08-2006, 05:58 PM   #13 (permalink)
View penguininatux's Photo Gallery
nice man.. i have the same intercooloer.. or atleast one really close to it. w/e you do dont let your a/f go lean. if you look up at "5sfe troubles" a few threads up you'll see what i did to my old pistons boosting 9 psi with messed up fuel management. Rubuilt the engine and now having a few troubleshooting errors.. anyways.. you can check it out.
penguininatux is offline   Reply With Quote
Old 03-18-2006, 09:13 PM   #14 (permalink)
Ok fixed oil problem... Found out that the oil return line was too small. Replaced with larger steel braided hose and no more blowing oil.. Something that simple.... Anyway now I am slipping in third fourth and fith gears at 7psi. Dosent slip until that boost. Dont understand I have a stage 2 F1 racing clutch. Says It supports up to 250hp. Any suggestions guys???
Old 03-19-2006, 02:08 AM   #15 (permalink)
haha i have the same one.. havent installed it yet though.. i spun a rod bearing after my recent rebuild, so im replacing the crank, and i just found out that i have to remove the tranny to take the crank off, so i think i might throw my stage 2 F1 clutch in also.. Its BLUE huh? well anyways. let me know how your f1 clutch holds up, cuz i wanna know. later.
iPod interface - finally brucethebear Archived Corolla threads 10 01-22-2006 11:25 PM
My Exhaust and Suspension Finally! (56k no way in hell) DAMON Show & Share 23 06-18-2005 08:13 PM
O yea... cam/TN curse Ruffrydasean Camry & Solara Lounge 15 12-12-2004 02:12 PM
Engine Swap Finally completed *pics* Tommy General Discussion 29 12-01-2004 08:31 PM
I Finally saw my first episode of Initial D!!!!!!!!!!! karma Archived Corolla threads 28 10-06-2002 08:41 AM
