Any one done a 3sgte swap on 92coup? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2006, 10:26 AM   #1 (permalink)
View 92ceilca's Photo Gallery
I got a 92 celica and i wanna do a 3sgte engine swap on it i know it will take alot of time i am willing to put that forth but what parts will it need to be succesful... i know it needs a v6camery trans or a mr2 trany but what else will i need a ECU? Also if i was just going to turbo a 1.6lt GT celica 92 what would i need??? please respond or email me tnx!
92ceilca is offline   Reply With Quote
Old 02-28-2006, 02:55 PM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
Yes, you will need the ecu and harness.
C.tech is a great place to do the research on 3sgte swap.
www.celicatech.com
93 ST185
ST185 is offline   Reply With Quote
Old 03-01-2006, 09:21 AM   #3 (permalink)
Unhappy
Appriciate the site refference man tnx.. i went to it last night couldnt find much on everything you need saw alot of problems tho...most of them seemed rather minor and easily controlled however...do you know what it would take to boost a stock 92celica gt?
Old 03-01-2006, 10:08 AM   #4 (permalink)
Gameroom cash: $147537
You say you got a 1.6L GT. You sure? Is it an import? I ask because GT in US and Canada got 2.2L 5S-FE. The 1.6L is 4A-FE. It does affect swap due to different engine mount and tranny.
Old 03-01-2006, 04:52 PM   #5 (permalink)
I got a 92 celica EFI 16 valve pretty sure that is SOCH not sure what ltr any one know?
Old 03-01-2006, 05:55 PM   #6 (permalink)
Its a DOHC. Do you see 2200, 2000 or 1600 on valve cover or intake manifold?
Like this:
Old 03-08-2006, 09:56 AM   #7 (permalink)
Ive got a 1.6 Sohc im sure now just checked it out i forgot the egngine code i got it at my house tho at work atm but ill post it up wheni get to it.
Old 03-08-2006, 10:23 AM   #8 (permalink)
Engine with a single timing belt pulley doesn't mean its a SOHC.
92 Celica got a handful of engines: US 1.6L 4A-FE, 2.2L 5S-FE, 2.0L 3S-GTE Japan/Europe 2.0L 3S-GE. They all DOHC, 4A-FE and 5S-FE and slaved DOHC with one timing belt pulley driving both intake and exhaust cams.
BTW all the above engines are 16V.
Unless someone swapped an old SOHC 4A into your car which should be a Carb engine.
Old 03-08-2006, 05:44 PM   #9 (permalink)
View penguininatux's Photo Gallery
yea the other cam gear is an internal subgear so the intake cam, which does have a pully, can rotate the exhaust cam in the opposite direction. and to boost a 2.2 it takes about 8 hours if you have all the right parts. i did it in a few days though because i didnt work on it consistantly.
what kind of engine management you considering?
penguininatux is offline   Reply With Quote
Old 03-12-2006, 05:10 PM   #10 (permalink)
not egzactly sure but thinking ecu.
Engine swap US 3SGTE 1991 > JAP 3SGTE 1994 - Pinout JesperDenmark MR2 Forum 12 03-20-2010 06:47 PM
3SGTE swap or 3SGE akujin MR2 Forum 9 05-17-2007 06:15 PM
3sgte swap into a 2.2 NA MR2 pdxvento MR2 Forum 12 03-28-2007 11:59 PM
3SGTE swap seminar @ TN meet allblackalltrac Celica Forum 15 02-27-2005 01:07 PM
I have some Qs about jdm 3sgte swap and prices? Do I need........ Five1Oh MR2 Forum 10 01-25-2005 08:31 PM
