Easiest way is to use whatever you had in the old engine.
The 18R-C, 20R, 22R and 18R-G dizzy inards are all compatible even though the dizzy body may be different.
So take the guts of your old dizzy, put it into the new 18R-G dizzy body and wire it all up exactly as it was before with the old engine.
This is how I had my 18R-G setup for a couple of years.
Once I had figured out how EI worked, it was a simple 1 hour job to shift to EI.
If you are confident and have all the relatevant bits, then EI is much better than points.
If you are not sure, then just duplicatethe old system
I highly recommend the Haynes manual because it has a very good wiring diagrams for both points (early models) and EI (later models).
You can see the wiring diagrams ei.pdf and points.pdf I made at
http://autos.groups.yahoo.com/group/...ng%20diagrams/
- Stepho
