Timing Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2006, 04:57 PM   #1 (permalink)
View projectcelica07's Photo Gallery
Gen5 Timing Question
Hey i need to know which way i turn the distributer to advance the timing. If im on the Driver side, do i turn it clock wise.... or counter clock wise.. and since i dont have a timing light how far should i turn it?
Also has anyone advanced there timing before? I heard it helps but then again iv heard you wont even feel the difference, i was just wondering what kind of results you guys got or what happend? Did it backfire more or sputter or will it cause anything bad to happen?
projectcelica07 is offline   Reply With Quote
Old 03-08-2006, 05:40 PM   #2 (permalink)
View penguininatux's Photo Gallery
clockwise.. since from the angle you are lookin at the intake camshaft, it is turning counterclockwise, you want to move the distributor clockwise so the metal rotar reaches each distributor pin sooner.
penguininatux is offline   Reply With Quote
Old 03-08-2006, 05:50 PM   #3 (permalink)
Gameroom cash: $147537
Don't touch it without a timing light.
Old 03-08-2006, 05:53 PM   #4 (permalink)
yea.. im assuming you have one....
Old 03-11-2006, 04:46 AM   #5 (permalink)
View bashattitude's Photo Gallery
All you are doing is advancing the ignition timing if you go too far all you are going to get is ignition ping and very little in performance if any at all it is best to leave it at manufacturers specifications for performance and efficiency. AND USE A TIMING LIGHT.
bashattitude is offline   Reply With Quote
Tercel 1992 Timing Belt - Urgent Question svyatets Tercel, Paseo, Starlet, and Sera Forum 3 12-25-2005 01:47 PM
timing belt question camrydarkstar Camry & Solara Lounge 1 01-27-2005 04:54 PM
87 camry timing question... Ryanrusden 1st & 2nd Generation (1983–1986 & 1987-1991) 1 01-22-2005 12:11 PM
timing belt follow up question... BobES300 Camry & Solara Lounge 7 01-03-2005 10:04 AM
