Strut insert will not come out! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2006, 02:33 AM   #1 (permalink)
View wiccanferret's Photo Gallery
'89 Celica GT, the coil and the mounting spring/bearing thing is off, I'm down to just the 50+mm nut type thing that holds the insert into the strut housing and it is stuck fast. It is supposed to turn, right? And should I be able to do it with my hand? If I should be using a wrench, where do I find a wrench that fits? The thing must be at least 55mm wide...
wiccanferret is offline   Reply With Quote
Old 03-12-2006, 03:05 PM   #2 (permalink)
Bump
Old 03-12-2006, 04:10 PM   #3 (permalink)
View canadiancelica's Photo Gallery
take a picture of said nut.
If im right, im thinking its the one connecting the strut rod to the upper strut mount ?
If not, enlighten me a little more
canadiancelica is offline   Reply With Quote
Old 03-12-2006, 07:25 PM   #4 (permalink)
No, it was the nut that actually held the cartridge into the housing. I got it off, finally, with the help of alot of liquid wrench and a buddy's vise.
Old 03-13-2006, 12:10 PM   #5 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
haha I used a machinist vise and a large pair of channel locks.
or you can put an iron bar in the holes and use a pair of channel locks for efficient leverage. Good Luck!
Make sure you have a bucket around there is a shit load of fluid that is in there.
thousand_five is offline   Reply With Quote
Old 03-13-2006, 12:19 PM   #6 (permalink)
He is talking about that crappy large black nut.
KYB ( any non OEM ) Strut mount for Gen3 Camry? Front? blueapple 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-26-2008 11:36 PM
Rear Strut Broken. Need Help. 3vz4me Camry & Solara Lounge 3 06-13-2005 12:29 AM
Serviceable (sealed) vs Non-servicable (non-sealed) Strut Info REAPER STRAIN Camry & Solara Lounge 1 01-20-2005 03:04 PM
Changing out strut mounts and spring bumpers - Advice needed (4th Gen Camry) Bob_98SR5 Camry & Solara Lounge 6 03-01-2004 07:17 PM
Strut Tower bars/Strut braces aleks77 Camry & Solara Lounge 22 10-21-2003 03:53 PM
