Wiring Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 03:53 PM   #1 (permalink)
View projectcelica07's Photo Gallery
Gen5 Wiring Help
Hey im tryin to make a homemade flame kit for my exhaust and i need cant get the wiring right.
Is this right im trying it next?
Im going to run a positive off the batter to a possitive on my switch then negative from the battery to a negative on the switch.... The do i run the spark plug wire from the positive on the switch to the exhaust?
I think it makes sense the only thing im thinking about is if the spark plug positive wire is spliced on the positive on the switch is it always going to run juice threw it or will it turn off when i switch it to off? Do i need a ground wire or not ?
projectcelica07 is offline   Reply With Quote
Old 03-16-2006, 08:14 PM   #2 (permalink)
Gameroom cash: $147537
You'll need a few 10000 Volt to fire a spark plug. Also you'll need a pulsing signal, not a constant voltage. I suggest you stop before you fire everything in your car with high voltage.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
Replacing head-unit on JBL system - wiring diagrams? explorer626 Audio, Video, and Security - Tech 1 02-06-2005 12:40 PM
Stock HU wiring color confusion.. rainman Audio, Video, and Security - Tech 1 02-02-2005 03:17 PM
head light wiring.. Jzs147-RR Archived Corolla threads 0 08-27-2003 07:26 PM
Please tell me if my wiring is burnt or what. RayRaymond Camry & Solara Lounge 20 04-14-2003 02:40 PM
