Ignition Problems? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2006, 04:30 PM   #1 (permalink)
View Sarstan's Photo Gallery
Ignition Problems?
For starters, my car is an '82 Celica GT. My father while he still had the car had trouble one day starting the car. He would turn the key and all the lights would come on and all, but the car would not turn over no matter how far he turned. To fix this, he ran a wire from the starter and one from the battery to next to the steering wheel and would have to put the key into the ignition and touch the wires to make the car start.
So there's the situation and the problem is I don't care much for touching two wires together after all these years to start my car. I just replaced the ignition switch wire that runs from behind the ignition to under the dash and it didn't help matters. Anyone have any ideas on this?
Thanks in advance.
Sarstan is offline   Reply With Quote
Old 03-19-2006, 11:29 PM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
Probably the key switch is worn out inside (this happened to my '87 Honda).
Replace.
It is also possible for the problem to be one of the old wires being broken inside (plastic sheath okay but metal wire is snapped).
Buy a copy of the Haynes or Chilton manuals, study the wiring diagrams and then start probing with a multimeter or light probe (light bulb and pair of wires connect to ground and the item of interest).
Test each connection on the key switch while turning the key through all positions.
This will give you a feel for what should be happening.
Also check the fuse panel.
Sometimes the connections are loose underneath.
- Stepho
stepho is offline   Reply With Quote
Old 03-20-2006, 12:14 PM   #3 (permalink)
Gameroom cash: $147537
Or simply a broken relay.
Old 03-23-2006, 08:52 AM   #4 (permalink)
View rocketracing's Photo Gallery
My bet is on the relay but there also could ahve been a short somewhere and that would have fried the fuseable link by the starter.
rocketracing is offline   Reply With Quote
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
Ignition Fuse Help Please..... shadetree714 Camry & Solara Lounge 2 09-05-2005 02:24 PM
problems problems problems... robehsi Camry & Solara Lounge 4 02-13-2005 02:43 AM
Introduction and question regarding Ignition Switch DXG4@msn.com Introduce Yourself Here 2 01-30-2005 04:55 PM
Ignition or starter problems spills1969 Hardcore Tech and Competition 2 01-18-2003 11:02 AM
