When Removing The Crankshaft - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2006, 02:11 AM   #1 (permalink)
View penguininatux's Photo Gallery
hey, i spun a rod bearing in myh 5sfte, and am replacing the crankshaft. i have 2 questions.. first off.. i removed the bolt in the crank pully, but the pully still is not coming off.. is the only way to get the special tool? and 2nd, i read somewhere that u need to remove the transmission to remove the crank.. is this true? i am assuming it is, because that makes sense, but its just a pain in the ass.. anyways.. let me know.. Thanks
DAN
penguininatux is offline   Reply With Quote
Old 03-19-2006, 02:11 PM   #2 (permalink)
Always Bored
View hachi-rocu's Photo Gallery
Yes I believe you have to remove the transmission to get the crank out because it is attached to the flywheel.
Using a pulley puller might be the easiest way to remove the pulley but there are other ways.
Remember to check and remeasure all the crap under there.
I have never done it for the money.......except for that one time
hachi-rocu is offline   Reply With Quote
Old 03-23-2006, 12:27 AM   #3 (permalink)
View jizneremie33's Photo Gallery
you need to get a harmonic balance puller to get the crank pulley off, and then the tansmission has to come off, and then the main caps and rod caps. You might want new main cap bolts and rod bolts too when you replace the bearings.
jizneremie33 is offline   Reply With Quote
Old 03-23-2006, 08:37 AM   #4 (permalink)
Gameroom cash: $147537
Take the whole thing out and rebuilt it. It'll last longer.
If you need the car, find another cheap 5S and throw it in.
Old 04-29-2006, 02:59 PM   #5 (permalink)
View psi4power's Photo Gallery
Make sure to get the rods resized or get new ones. The rods wear on the big end and cause problems like spun bearings.
psi4power is offline   Reply With Quote
Old 05-02-2006, 07:00 AM   #6 (permalink)
View maxpower_hd's Photo Gallery
I agreee with Pinnapple. Just pull the motor and get it over with. Buy a rebuild kit and do it right. It will be easier in the long run than trying to roll in bearings and a crank from under the car and you will have a better job too.
"The normal make a living. The deranged make history." -Christopher Titus
maxpower_hd is offline   Reply With Quote
New technique for removing crankshaft bolt Kayakertom Tercel, Paseo, Starlet, and Sera Forum 16 08-06-2011 10:54 PM
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
Crankshaft pulley trouble... BIG BIG TROUBLE!! and little bit of reading... _VVTi_ Camry & Solara Lounge 12 06-18-2005 09:20 PM
Best way to remove crankshaft pulley nut (flywheel inspection cover?)? awmccready Camry & Solara Lounge 5 11-26-2004 11:58 AM
Help removing crankshaft big pulley! xiongmoua Camry & Solara Lounge 10 11-08-2003 12:33 AM
