Thanks SO much "Pineapple" and "ST185" - went to a local junkyard and got everything (including the sunroof assembly) for just under $50! BTW, great instructions from that link, ST185.
Now I wasn't sure to start a new thread or continue here, but the sunroof only slides all the forward or all the way back if the following 3 steps are applied:
From a completely closed position, to slide it back (open) you must:
1) Press and hold "Slide back" (this will bring it to approximately the halfway point)
2) Press and hold "Tilt up" (this will bring it to approximately 75% open)
3) Press and hold "slide back" again to bring it all the way back.
To close, the opposite buttons would be pressed.
Is this correct...should there be 3 steps to opening or closing the sunroof?
The owner said she remembers pressing the "slick back", which would bring it about halfway (as it does now), but then she would press "slide back" again to completely open - didn't remember having to press the "tilt" buttons, but is VERY pleased it's working again!
Any ideas about this?
Thanks again for the replies...they were a HUGE help!
