gaskets - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2006, 10:54 PM   #1 (permalink)
View Wrinkeld_GT's Photo Gallery
Gen5 gaskets
will a stock 5s head gasket be good for 7 psi or should i go with a cometic head gasket. don't the head gasket from the camry bolt on?
Wrinkeld_GT is offline   Reply With Quote
Old 04-12-2006, 08:27 PM   #2 (permalink)
View Saggz's Photo Gallery
Stock high mile headgasket might be ok.. for a little while. If you plan on going turbo, I would swap it for a metal or new oem gasket. Some Camry headgaskets will work, there were 3 'generations' of 5SFE, the first was in 90-91 Celicas and the second in 92-93 and the third used coilpacks, found in the 97+ Camrys. I believe the 90-91 Celica motors were the same as 90-93 Camry motors, and 92-93 Celica motors were the same as 94-96 Camrys. The difference is in the coolant passage locations.
Saggz is offline   Reply With Quote
Exhaust Gaskets Strat42586 MR2 Forum 3 02-28-2005 11:29 PM
Metal Head Gaskets Zach Ayres Supra Forum 5 08-26-2004 01:23 PM
3vz Copper Head Gaskets - Interest?? zoni Camry & Solara Lounge 4 08-26-2003 08:12 PM
3vz rebuild kit and METAL head gaskets??? zoni Camry & Solara Lounge 1 06-27-2003 01:24 AM
