reverse lights/dome light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2006, 08:05 PM   #1 (permalink)
View tsuave's Photo Gallery
2 problems....
1: the reverse lights don't come on. i have a 90 auto celica gt. i checked (in case hell froze over) and the bulbs were fine....(rare chance both would go out)
2: the dome light doesnt come on when the driver's door is open, but it does when the pass. door is open....where is the switch that triggers when the door is open....
3 problems i guess....where is a cheap place to get the FSM online...either digital or actual book....
Thanks!
tsuave is offline   Reply With Quote
Old 04-12-2006, 11:08 AM   #2 (permalink)
View BlckShadow's Photo Gallery
there should be a switch for the reverse lights under the center counsil and the switch for the door is in the door jam right below the door latch, neither of mine work so its probably common problem
BlckShadow is offline   Reply With Quote
Old 04-12-2006, 10:04 PM   #3 (permalink)
View Saggz's Photo Gallery
Easy and cheap fix for the door lights, unscrew the switch by pulling back the rubber on the bottom, it'll come out and you can disconnect it. Then take some electronics cleaner ($3 or so) and spray the stuff inside the switch itself. You may need to take a thin piece of metal or plastic wrapped in sandpaper and slide it into the switch itself, it'll be more clear when you take it out, then spray again. Takes 5 mins.
As for the reverse switch, its likely an unplugged harness off the tranny.
Saggz is offline   Reply With Quote
Old 04-12-2006, 10:41 PM   #4 (permalink)
my door switches are levers that unspring when the door is open....if i take out the lever i get a hoel with a nother lever that the first lever actuates....i can see no electrical anything becasue its all in the dorr cavity and i only have a 1" hole to work with...kinda like your mom...sorry 3rd grade joke but it was there....
thanks for your help
Old 04-12-2006, 11:57 PM   #5 (permalink)
You're not trying hard enough, oddly, thats exactly what I say when I demand my quarter back from yo momma.
Aside from that little lever, theres a rubber accordian like thing that you will be looking at dead on when you kneel (and it seems you should be familar with kneeling) at the side of your car, looking in. Pull up the bit of rubber at the bottom and you can follow along with my other post.
Old 04-13-2006, 10:19 AM   #6 (permalink)
the lever thing is for the seat belt retractor, the rubber switch for the light is below that
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 08:40 AM
87 camry reverse lights don't light up ericksonm 1st & 2nd Generation (1983–1986 & 1987-1991) 4 08-28-2005 08:13 PM
6000K, 7000K, 9000K, 12000K???? - explination of light/color in terms of Kelvin "K" BLUEMEANIE General Discussion 11 07-03-2005 06:57 PM
reverse light question TypeZer0 Camry & Solara Lounge 16 05-22-2004 09:43 PM
AE92 trunk light mod homeguard Archived Corolla threads 25 04-18-2004 06:50 AM
