rich/lean problem with 5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2006, 11:31 AM   #1 (permalink)
View BlckShadow's Photo Gallery
ever since i had a new clutch put in my 90 gt, its been throwing codes for running too rich and running too lean. i replaced the o2 sensor and rewired the harness side of the sensor and it didnt help. if anybody has had same problem or knows how to fix it please let me know. thanx
BlckShadow is offline   Reply With Quote
Old 04-12-2006, 08:31 PM   #2 (permalink)
View Saggz's Photo Gallery
Possibly vacuum leak. Did you pop off any lines and forget to connect them? Connected them incorrectly? You'd be surprised how many little problems can be caused by a leak.
Saggz is offline   Reply With Quote
Old 04-11-2010, 01:38 PM   #3 (permalink)
I'll Drive Anything
View Cammoe's Photo Gallery
So what ended up being the fix for your rich lean codes, because I've got a 92 5sfe throwing them now after replacing motor. Car runs great, lots of power, but check engine light comes on and throws 25 and 26 code for to lean and to rich. Have tried lots of things all with no luck.
-Cleaned Throttle Body (replaced gasket too)
-Tested for air/vacuum leaks (none)
-Replaced fuel pressure regulator on fuel rail
-Replaced Fuel pump and fuel filter due to low fuel pressure
-Adjusted throttle position sensor
-Checked timing (at crank, cams, and distributor)
-Cleaneed spark plugs
-Replaced upstream o2
-Replaced all vacuum lines
Please help if you can
Cammoe is offline   Reply With Quote
Old 04-11-2010, 03:42 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $875075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Check your AFM. Maybe there's something hindering the flap.
The Jedi Speeder at CarDomain
2005 Corolla LE dashboard/door alignment problem richs Archived Corolla threads 8 09-21-2005 05:02 PM
Corolla 2002 bogging problem jojos Archived Corolla threads 7 08-02-2005 08:23 AM
87 Corolla hesitation problem. Bad_dude Archived Corolla threads 8 10-25-2004 05:31 PM
94 5sfe oil/engine problems a94autoCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 8 10-20-2004 06:08 PM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 11:42 AM
