3sge C/R???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2006, 11:37 PM   #1 (permalink)
View The Black Camry's Photo Gallery
3sge C/R????
I have a 3sge and plan to turbo so my question is, What is the compression raito of my 1st gen 3sge?
The Black Camry is offline   Reply With Quote
Old 04-23-2006, 11:55 PM   #2 (permalink)
never mind i found it!
Old 04-23-2006, 11:55 PM   #3 (permalink)
but Is 9.2:1 safe for boost and how much boost!
Old 04-24-2006, 07:21 AM   #4 (permalink)
View canadiancelica's Photo Gallery
Yes, 5-7lbs if you have good compression, rings, head gasket, bearings
canadiancelica is offline   Reply With Quote
Old 04-25-2006, 10:54 AM   #5 (permalink)
Well my brother is running 10psi in his grand am and it has a c/r of 9.5:1
Old 04-25-2006, 10:12 PM   #6 (permalink)
The 3sge is bacically the engine that Toyota boosted in the alltrac, withother modifcations. But they also boosted it from the beginning of its life. you're talking about boosting an engine that is ancient now and is guaranteed to have compression loss and leaky seals, rings, valve stem seals and worn bearings.
Go ahead and out 10lbs to it, see what happens. THen come back and ask us what you need to rebuild the engine.
FReshen it, then boost it, be smart, not a smartass
Old 04-26-2006, 12:31 AM   #7 (permalink)
i already did rebuild my engine!!!!
Old 04-26-2006, 04:57 AM   #8 (permalink)
you could have said that in YOUR first post, more info = better advice
Old 04-26-2006, 09:05 AM   #9 (permalink)
WEll in my first post i only wanted to know C/R.
Old 04-26-2006, 04:39 PM   #10 (permalink)
see, there's the smartass again.
Fine smartass, in your 3RD post, you should of stated that
Old 04-27-2006, 01:48 AM   #11 (permalink)
Im not trying to be a smart ass. you should take your own advise and be more specific also!
Old 04-27-2006, 10:20 PM   #12 (permalink)
if you have the 3sge rebuilt and it has soild balanced compression, then it should take 10psi all day long no problems. Do a little more research into the 3sge versus the 3sgte and you will find all the information you need.
3SGTE swap or 3SGE akujin MR2 Forum 9 05-17-2007 07:15 PM
89 3SGE / 3SFE interghangable parts 89GTS Celica Forum 12 07-10-2006 10:24 AM
3SGE and 3SFE, lets get our heads together almc2242 Hardcore Tech and Competition 9 01-27-2005 04:58 PM
Stock 87 ST 3SGE, common? (my sprinter is born, muhaha!) Slip_87 ST Celica Forum 16 11-17-2004 06:29 AM
Celica St162 - 3sge Turbo???? smt_007 Celica Forum 9 10-30-2003 09:24 PM
