Only onther "simple" possibility is a bad upper strut mount. They're going in my GF's car it sounds like a rattle, but it only happens on mild bumps, not larger ones, and at high speeds (wheel vibration).
But then again, you could be looking at a bad tie rod end, bad ball joint, bad sway bar link, rusted sway bar - to chassis mount, dried out/shrunk suspension bushings, cracked spring, blown strut.
Something in the front end is VERY VERY difficult to diagnose via the internet. A garage can test the majority of these possibilities simply by putting on a life, jiggling the wheel, using a stecheschope to check the bearing, physically moving the sway bar, visually checking the bushings/spring/strut for leakage, upper strut mount is harder to check while it is in the car. Removing it will tell u immediatly, it will be rough and loose.
Good luck to ya !!!
