turbo celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2006, 07:28 AM   #1 (permalink)
View Turner's Photo Gallery
USA turbo celica
i have a 1994 celica st (1.8l). i am looking to turbocharge it but am having trouble locating a kit for this aplication. if anyone has any knowledge about this project please let me know.
Turner is offline   Reply With Quote
Old 05-05-2006, 10:25 AM   #2 (permalink)
View A Diddy's Photo Gallery
if i was you I would buy the stock turbo celica engine rather tha a turbo charger. There is an engine called the 3sgte that is built for turbo and is easily built up for high boost. Its the stock engine for the all trac celicas and the mr2s. Will probably be cheaper to.
2004 G35 6MT
1991 3sgte Celica GTS
A Diddy is offline   Reply With Quote
Old 05-05-2006, 07:40 PM   #3 (permalink)
Always Bored
View hachi-rocu's Photo Gallery
check out www.6gc.net for some good info
I have never done it for the money.......except for that one time
hachi-rocu is offline   Reply With Quote
Old 05-09-2006, 06:43 AM   #4 (permalink)
USA
i concidered that but iwas told that i would have to replace the wiring harnes and the motor mounts.
Old 05-09-2006, 11:59 AM   #5 (permalink)
well if u get a new engine than u wil get the motor mounts and it should (unless you bu it without one) the wiring harness
2004 G35 6MT
Old 05-09-2006, 12:34 PM   #6 (permalink)
Gameroom cash: $147537
^He's ST with 7A-FE. Turbo would be a bit easier then 3S swap. For 3S-GTE swap you'll need tranny, ECU, wiring, mounts maybe even axle and hub.
Look for turbo manifold and buy a turbo that fit. Or get a shop to make a manifold for the turbo you want. Try eBay.
Old 05-09-2006, 08:27 PM   #7 (permalink)
piney does the super charger bolt on to his car?
2004 G35 6MT
Old 05-10-2006, 07:28 AM   #8 (permalink)
im on ebay right now and all that is coming up for turbo manifolds are the one for the 3s-gte motor. will that bolt on or no? they also have one for a 2000 celica gt?
Old 05-10-2006, 08:23 AM   #9 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
Niether of those will bolt on.
I believe the manifold from a B series Honda will bolt up. The flange at least. You will probably have to modify the piping.
What are your goals?
You might be better off doing the 3SGTE swap.
Also, just so you know, your engine is a A series [family]. 7AFE. The 3SGTE is a S series. Pretty much nothing matches up.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 05-10-2006, 09:29 AM   #10 (permalink)
7A-FE Turbo Manifold
Get a shop to custom made one. I believe there maybe turbo kit, try Google.
Old 05-10-2006, 05:01 PM   #11 (permalink)
Always Bored
You could always swap in a 20V they have lots of parts for them.
Check out the 4age line up
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Turbo the tercel? Flymasta K Tercel, Paseo, Starlet, and Sera Forum 19 01-30-2005 11:38 PM
