i do have a manual but it doesnt hav some of the litle things... i dont have a BVSV or EGR VACUME MODULATOR or EGR VALVE so i have connected line 3 direct to the throttle body that should work right... its the same line with some components cut out. but where does the bottom (fresh air ?) line connect and the other line on the top... fuel tank maybe.
being an import motor from a camry it doesnt have all the emmision gear it should but i will sort that once its all running
i thought the power steering connected there cool.
thanks so far just need those last 2 lines on the charcole cannister
