2 Bar Map Sensor Turbo Rich A/f's
5SFE TURBO
Alright, i talked to a few people about this subject of using an msd 2 bar map sensor. My problem was that i was just gettin wayy rich readings at idle and during acceleration ( too rich to even drive), with my new 460cc's being controlled by an SAFC II. Anyways, i heard from a few people that using a 2 bar would help lean out my a/f's throughout idle and all rpms. So i installed it today. Seems like nothing has changed. I tried wirinig it in differently with no change again.
First off does anyone know the wiring of of a stock 5sfe map sensor, and then one for the 2 bar MSD pt#2312?
( just so i know i wired it in correctly)
And secondly. Why arent my a/f's dropping after installing the 2 bar? should they be?
feeback is greatly appreciated (seriously)
Thanks
Dan.
Innovate wideband btw.
Oh and for Manny (pressure2) if you're lookin at this. or someone else with a similar to setup as us, if you could remove the 2 bar while idling (just the plug) and see if you're a/fs get really rich. that would help to determine if the 2 bar map actually makes a difference in A/F's
Thanks again to anyone who has the time to help!
