Failed Smog For 90 Celica GTS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2006, 05:09 PM   #1 (permalink)
View blackaneseazn's Photo Gallery
Gen5 Failed Smog For 90 Celica GTS
Hey everybody,
Need some help here for those familiar with smog check repairs. I brought my 90 Celica GT-S in for its every two year smog check. These are the results that showed why it failed. The non passing parts are the Functional Check, Emissions Test, and Ignition Timing: 5 BTDC. This was how it read out. Any suggestions for what needs to be repaired?
blackaneseazn is offline   Reply With Quote
Old 05-23-2006, 02:03 AM   #2 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
change your fuel cap. thats an automatic fail.
89CelicaGTTurbo is offline   Reply With Quote
Old 05-23-2006, 02:15 AM   #3 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
Gen5
Do you guys think the emission place is bogging the engine down, by running at those rpms of less than 2000?
thousand_five is offline   Reply With Quote
Old 05-23-2006, 02:39 AM   #4 (permalink)
89CelicaGTTurbo, the fail is not for the fuel cap functional but rather the ignition timing: 5 btdc as the results read to the right for the ecs. I also forgot to mention that they put automatic transmission instead of manual. Perhaps this makes a difference? I'm not sure.
Old 06-01-2006, 01:07 PM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $263590
View Doctor J's Photo Gallery
High NO suggests EGR system. .5% CO plus 120 HC calls for evap system. Replacing fuel filler cap gasket and checking EGR vac. modulator may help.
I also noticed from your previous posts that the car has rough idle.Open diag. box and measure voltage between Vf and E terminals, it must be close to 2.5 V. For more info., refer to Autoshop 101.com, technical articles by K.Sullivan.
Doctor J is offline   Reply With Quote
Old 06-01-2006, 01:42 PM   #6 (permalink)
The previous post I made about a rough idle was solved by replacing the timing belt. After my car died out and the belt broke, replacing it solved the issue. Now in terms of the smog issue, I also didn't mention that when I bought this car, there wasn't a secondary catalytic converter and I think that may be the culprit for failing smog. This was a few years back when I wasn't as aware about cars so I wasn't aware of this and figured all it needed was the main catalytic converter (located right by the engine). I'll probably start by having a secondary catalytic converter put in. According to the fat service manual, there isn't a oxygen sensor on the catalytic converter itself to be plugged in. Maybe it's just this year's model that applies to that. If the catalytic converter doesn't solve the problem, I just might need to dump some cash for a diagnostic test to see what is the problem.
1991 Celica GTS questions? TeRcElIcA Celica Forum 5 03-13-2005 09:23 PM
92 Celica GTS Plat Celica Forum 7 06-21-2004 09:07 PM
What other type of tranny fits my celica gts 86 ? prizmatik Hardcore Tech and Competition 1 09-04-2003 11:53 PM
