The 5M-GE will fit but it is a
very tight fit.
Not supercharged but 2800cc give respectable performance (and doesn't have a reputation for blowing head gaskets like te 7M does.)
The supercharged 1G-GZE will fit but it is a tight fit and hard to find in the USA (except possibly in the IS200).
The 1JZ and 2JZ will fit but is a
very,
very tight fit and may cause trouble with too much upfront weight.
Also, I'm not sure if it has a supercharged version.
Even in n/a form it will give good power.
http://www.members.iinet.net/~coolti...1JZ%20RA23.htm
http://www.norbie.net/jza23.htm
(note the RA23 has the same engine bay as your RA29)
If all this sounds a bit much, then consider putting in a 22R.
It's practically a drop in replacement for the old 20R.
Even better if you use a 22R block with a 20R to raise the compression ratio.
http://ourworld.compuserve.com/homep...pho/eng20r.htm
You might even try a 22R-TE turbo inlet manifold connected to a supercharger.
I'm not sure if any superchargers bolt up to this manifold easily.
Of course, you would still have to worry about converting the carby to be pressurised or consider swapping up to EFI (not as hard as it sounds and the 22R-TE manifold is already setup for injectors).
- Stepho
