Stalling and low/rough idle
1982 Toyota Celica GT. I just installed a fresh Starter on the vehicle and started it up and it ran fine, then I went and (quite foolishly) used one of those engine degreasing products to clean the engine since it was coated in oil. Whatever the case, it required the engine to be hosed off and I thought the carborature mounting was closed tight, but after spraying off under the hood, I turned it on and it started to rough idle and die on me. I looked under the hood and found the carburator had small beads of water on the pedal. I wiped it off and checked the distributor and it was clean and dry inside and out. I changed the spark plugs, fuel pump (it needed it anyway), wiped out, cleaned, and dried most everything I could without tearing the car apart and still the same problem. It dies on it's own and I can drive it around as long as I keep giving it gas at a stop or it's moving (to which without gas, it'll stumble). I've been also trying to "burn it out" the first few days, but after about a half hour and up of trying that, it didn't work. Right now I've increased the idle to compensate, but it still jerks and stumbles and dies at times at stops.
So the question. Any ideas? I'm thinking of changing the fuel filter at this point since I blew it out the first day and it helped a little (but not for too long).
