Celica transmission help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2006, 07:00 PM   #1 (permalink)
norcalRA64
View norcalRA64's Photo Gallery
I have a 1982 Celica GT(RA64) and the tranmission has been slipping really badly and I have decided that it's time to replace it. I have the know how and the money to buy and install one, but I can't seem to find one for my car. The car is a 4-speed auto with over-drive. I found one for an 84' celica gt, but I'm not sure if I can use it, because I don't know if it's any different. If anyone could help me out with this one I would really appreciate it, thanks!
norcalRA64 is offline   Reply With Quote
Old 05-29-2006, 12:39 AM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
82 to 85 Supra and Celica autos are interchangeable.
You can also use the auto box from Coronas, Cressidas and Crown from similar years.
In fact almost an automatic Toyota from 1978 to 1985 can provide an A40D gearbox.
If you use an auto that was attached to a M series engine, then make sure you use your old bellhousing.
You might have to use the speedo drive gear from your old gearbox, depending on the donor car's diff ratio (ie speedo might be incorrect range).
If you are not sure, then look at the gearbox code on the build plate on the firewall in the engine bay (for an RA64 it should say A40D).
Then look for a donor car of similar age that also says A40D on the build plate.
- Stepho
http://ourworld.compuserve.com/homep...od.htm#cel64pr
stepho is offline   Reply With Quote
Old 06-02-2006, 10:04 AM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $263590
View Doctor J's Photo Gallery
Be careful about starter location; bellhousing may not fit
Doctor J is offline   Reply With Quote
Dead transmission & clutch (2004 Corolla S) dormondlin Archived Corolla threads 2 10-03-2005 07:34 AM
Celica GT vs. Celica GTS Dangerousmind58 Celica Forum 15 09-16-2005 04:18 PM
98 Celica GT-S (Opinions) elvasoshexai General Discussion 13 08-11-2005 07:58 PM
