clutch or tranny? please help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2006, 09:31 PM   #1 (permalink)
View LoCeliCal's Photo Gallery
sup ....i need help with my 5th gen celica. its a 1991 toyota celica st. so here is my situation, when i press the cluth and ingage to first gear everything is fine, but when i try to go its dosent go anywhere and a loud noise sqeels from the engine. so i try any othe gear to see if it goes in and it lets me, but as soon as i try to go it jerks for a moment then the loud noise comes from the engine and the car dosent go anywhere. it feels like the clutch is not engaging to move the car. so im thinking its the clutch or the preasure plate. im really hoping its not the tranny. thanks for any help.
LoCeliCal is offline   Reply With Quote
Old 05-29-2006, 10:29 PM   #2 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
it is the clutch. same thing happened to me. dont worry its not the tranny.
89CelicaGTTurbo is offline   Reply With Quote
Old 06-26-2006, 10:36 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
put the car in gear with the motor off, can you push it?
Old 06-27-2006, 06:12 PM   #4 (permalink)
View shant's Photo Gallery
i have a similar problem ! let me explain it ..
#1 im 100% sure my clutch is finished but thats not the problem !
when im in 1st gear and i wan't to put it in 2e it not going to get it ... its going to grind then go in .. my solution now is to rev mach the gears together with sound and experiance .. i can make it without any grinding ! but my question is .. is the clutch doing this or i need to change the clutch and the tranny ?
btw the 2e gear is the only one doing it ... and to down shift from 3 to 2 .. its impossible there is going to be to much grinding !
thanks !!!
shant is offline   Reply With Quote
I have a manual tranny and no clutch cancel switch??? LiquidClen 2nd Generation (2005+) 2 02-03-2006 08:55 AM
signs of tranny problems bowlofturtle Camry & Solara Lounge 1 04-10-2005 01:02 AM
new clutch = broken wallet eyz closd MR2 Forum 4 03-12-2005 04:16 PM
RPS Sport Series clutch w/ street disc INSTALLED mistamatrix 1st Generation (2003-2008) 4 06-30-2004 11:31 PM
