I know that 1UZ-FE will fit in an RA6# engine bay.
The 2GR can't be any big than that.
http://en.wikipedia.org/wiki/Toyota_GR_engine
http://en.wikipedia.org/wiki/List_of_Toyota_engines
I'd say it is doable by an experienced enthusiast but not recomended for a novice.
Pay attention to the following:
- Sump position relative to crossmember,
- if the 2GR-FSE tailshaft has no uni-joint near the gearbox then consider swapping to IRS (use Cressida MX73 or MX81 as donor),
- make sure gearbox and diff are perfetly aligned or vibrations will shake you apart.
- exhaust manifold may interfere with steering column( use extra unijoint and extra shaft held in place SOLIDLY by quality tie rod ends to bend around manifolds),
- upgrade to EFI pump, EFI filter and add a surge tank,
- upgrade to thermo fan mounted in front of the radiator (more space and robs less HP than standard fan),
- Standard Celica T series diff is too weak( use Cressida MX72 F or even better Cressida MX81 G series diff),
- upgrade front/rear brakes.
Overall, I don't think it will be as difficult as you think if tackled step by step.
The price of the 2GR-FSE might be prohibitive.
Think about a 1UZ-FE (260HP standard).
Much easier to find and much cheaper.
Many people have added twin turbos by pointing the exhaust manifolds forwards and upwards instead of backwards and downwards.
The engine is easily strong enough to make serious HP without any internal mods.
- Stepho
http://ourworld.compuserve.com/homepages/stepho/mods.htm#CarinaV8
