Wow, that's alot of miles.
~194,000.
Just a word of advice, most of us are in the US, and use the English system, not metric.
Most have no clue how many miles that is.....
Anyways,
In no particular order,
Standard size wheels on the GTS are 14 or 15", depending on trim.
Bolt pattern is 5 x 114 I believe.
It sounds like the GTS you have is NOT loaded.
Loaded GTS comes with auto ac, moonroof, 15" aluminum wheels, leather, system 10 sound, and a bunch more stuff. A factory alarm was also available.
A GT interior will be similar, depending on trim.
As far as interior, the seats won't be as nice, and it won't have as many options, depending on what this one came with. Door panels will be the same, unless the GTS has system 10 [it will have a 8" woofer in the door]. Dash layout is identical, as is center console. There was an option for a larger center armrest. I don't know if it was availabel for the GT/ST.
The GTS and Alltrac only have the widebody [those sexy fender flares].
That is a bit high milage, but the Celica is reliable past that, depending on care....
Have you looked underneath the engine to see how clean it is?
Valve cover gasket replacement is normal for that many miles. Also expect the dist seal to leak, as well as possibly the rear main and oil pan, and cam seals.
The head gasket will also probably leak, but only oil in the back, not a combustion leak.
The trans is pretty much bulletproof. Transmissions are Toyotas strong point.
I don't know what it's worth up there, every region is different.
Look for rust in the rear wheel wells, on the fender seam. Also under the car, on the 2 "rails" that run front to back on the floor pan.
One nice thing, the 90s only [in the US anyways, I believe Canada is the same] came with a MUCH nicer cloth. The 91 ^ is alot rougher. If it doesn't have leather.
92 Alltrac, 85 PU
