'88 GT 'vert - GTS rear disc brake conversion
Hello,
I recently acquired 1988 Celica convertible. Currently I am going through the car, performing all the essential maintenance. Timing belt, idler/tensioner, h20 pump, etc.
I have also purchased upgraded suspension pieces: KYB GR2 shocks with Suspension Technique lowering springs. Will be replacing CV axles, balljoints & tie rod ends, when installing the shock/springs.
Now for my question: The car has drum brakes on the rear, which I would like to convert over to a disc setup. Knowing that the GTS model came with disc brakes all around, I am interested in knowing if these pieces would be a bolt on solution. Or require some minor modifications.
My other question is in regards to wheels/tires. The car is still riding on its stock 13" rims, so I am looking into buying some 17's. My concern is which size tire and the offset of the wheels themselves, so there's no clearance issues, or rubbing.
Thanks for your feedback.
-David
