Remove/Install 93Celica starter? Help ASAP Please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2006, 09:40 AM   #1 (permalink)
View Valgar's Photo Gallery
Exclamation Remove/Install 93Celica starter? Help ASAP Please
Hello I am trying to work on the starter in my 93 Celica ST coup.
I see where the starter is located be hide the engine, under the intake manifold. From what I see there no easy way to get at it to remove and repair it. So I did a little poking around, I got under the car and saw that I also couldn’t access it from there either. As far as I can tell the only way to get at it is to remove the whole intake manifold, which for me work take a lot or work and likely more tools and know-how then I have.
I am hoping someone here knows an easier way to access the starter in a 93 Celica, or has a link for a how-to to remove it on a Celica. I have searched Google and haven’t found what I am looking for yet. Again I just need to know how to get at it and remove it.
Please help!
-Val
Valgar is offline   Reply With Quote
Old 06-15-2006, 12:17 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
It's actually pretty simple.
That crossmember is easy to remove. The bolts and nuts are on tight though.
There might be a 14mm bolt in the center as well, possibly under a rubber cap.
Go to www.Celicatech.com, go to the Navigate bar on the right, find the BGBs online, and look up V 1 for a 93 Celica.
You have to be a member to view, but it's free and all, just like this site.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 06-15-2006, 12:51 PM   #3 (permalink)
exactly what I needed, THANK YOU
3.4L V6 Starter Problems - A Follow-Up toto 1st Generation (1995.5–2004) 0 05-27-2006 02:42 PM
Starter Stuck Starting d0rkiishchris Camry & Solara Lounge 4 02-19-2006 12:18 PM
Need Help With Starter Eye8Pussies General Discussion 9 05-24-2005 03:58 PM
Starter Problem clauser Camry & Solara Lounge 2 03-09-2005 06:50 AM
Starter noise while engine is running shogun6684 Archived Corolla threads 0 02-21-2005 01:17 PM
