Overheating 94 - fan not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2006, 07:33 PM   #1 (permalink)
View acileC's Photo Gallery
Canada Overheating 94 - fan not working
hi, Im sure this is probably a relatively easy one, but my rad fan is not working. Ive found 3 relays, actually, I think found more., there's one box sitting on top of the rad, then the one on the passenger side which has "Fan 2" and "Fan 3" in it. (where is three? I see two)
then in the main fuse panel on the drivers side, there is yet another which says fan.
is there a test? is it likely a relay issue?
help please.
thank you in advance
acileC is offline   Reply With Quote
Old 06-17-2006, 08:04 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
You should put what Celica you have in your sig or something.
That way we know which when you need help...
Look on the bottom of the rad. There should be a electrical connector.
It is for the fan switch.
Unplug. If the fan works, that switch is bad.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 06-17-2006, 08:11 PM   #3 (permalink)
ok, thanks!
Old 06-17-2006, 08:15 PM   #4 (permalink)
is this the "temperature switch?"
my problem is, Im in another city from my car right now, and working through this with my father. he said the fans are running manually, and relays are fine. also said it could be the temperature switch but he doesn't know where that is and cant be bothered looking.
so I need this info for when I go tomorrow.
thanks again.
Old 06-17-2006, 10:06 PM   #5 (permalink)
Alltrack Wannabe
You STILL didn't put what kind of Celica.....................
Dunno.
What do you mean by temp switch?
It probably is.
Tell him to look where I told you.
If you had what type Celica, I could be more specific.........................
92 Alltrac, 85 PU
Old 06-18-2006, 06:21 AM   #6 (permalink)
gts
2.2
Old 06-18-2006, 05:35 PM   #7 (permalink)
Alltrack Wannabe
Ahh.
There we go.
I can't find a pic of it in the car, but if you locate where your lower rad hose connects to the rad, and look RIGHT NEXT TO IT, you will see a electrical connector.
That is the fan switch.
Unplug it and if the fan runs, it is most likely that switch...
92 Alltrac, 85 PU
Old 06-19-2006, 09:14 AM   #8 (permalink)
it is the switch that is bad. thank you very much.
Old 06-19-2006, 09:52 AM   #9 (permalink)
one more question...
what would the disadvantage, besides wear and tear on the fan motors, of just pulling the connector and letting the fans run for a few weeks until I have time and money to replace this switch?
Old 06-19-2006, 01:45 PM   #10 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
There really isn't any disadvantage except for it will put a strain on your electrical equipment. Alternator + battery.
thousand_five is offline   Reply With Quote
'94 Camry headlight 'feature' not working? Yucca-man 3rd & 4th Generation (1992–1996 & 1997–2001) 11 11-18-2005 05:48 AM
please help gal with radiator fan relay switch question atoyotchick Tercel, Paseo, Starlet, and Sera Forum 3 11-09-2005 12:13 AM
overheating still, basics covered dohcrxl Camry & Solara Lounge 12 08-28-2005 12:39 PM
MK3: electric fan kit vs. flex fan kit supertoy Supra Forum 4 09-14-2004 03:56 PM
A/C condensor fan and radiator fan stay on johnw Camry & Solara Lounge 11 03-27-2004 03:52 AM
