I can relate to your situation.
So, you need a photo of the water temperature sensor and connecting wiring coming out of the harness. Unfortunately I can't help. Perhaps someone on TN can.
One more thought. Does the plug you found fit the water temp sensor on the car? If your wiring was bad, brittle, the plug you see may be the original off your car. It may have just broken off. You may have clipped it off because the wiring was bad and you were going to fix it, later.
You may not be looking for a plug after all, but the ends of the wires where it used to attach. The wires have to be somewhere on the harness unless you removed them completely. I am sure you did not do this. You may have just taped over them. Undo the tape within say 6 inches of the sensor and see if the wires are there.
