a few questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2006, 02:59 PM   #1 (permalink)
5th Gen Celica man
View ELCelica's Photo Gallery
Gen5 a few questions
ok so I have some questions about my 93 Celica GT
1. has anyone changed the gauge faces in their 5th gen Celica? I'm considering it, but I'd like to know if this is easy or difficult
2. the brakes also need replacing, but I'm not sure on drilled only or drilled and slotted. a few sellers have said that slotted rotors tear up the brake pads, so unless the car will spend a lot of time on the track (which mine won't) there's no point. what do you think?
ELCelica is offline   Reply With Quote
Old 06-26-2006, 09:23 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
It will a slight bit.
But it will also depend on the quality of the rotors [cheap metal won't wear the pads as fast] and the pads....
But do you really need slotted?
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 06-27-2006, 10:10 AM   #3 (permalink)
Gameroom cash: $147537
Change gauge, nop, but I put blue LEDs in it.
Use drilled or plain rotors, prefer plain and put good pads on them.
Old 07-06-2006, 05:43 AM   #4 (permalink)
5th Gen Celica man
no probably don't need slotted, but definitely drilled.
How hard was putting the blue LED's in?
1993 Celica GT Liftback ST184 w/ 2.2L 5S-FE 5 speed stick
Cardomain: http://www.cardomain.com/ride/2501416
Old 07-06-2006, 09:21 AM   #5 (permalink)
As long as you can solder, it's not hard. Remove the dash, remove the bulb holder, remove the bulb, put in the LEDs, put them back, if LED don't turn on rotate 180. Trick is you'll need to bend and aim the LEDs so you don't have bright spots.
2000 camry questions dimask 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-06-2006 10:14 PM
Celica modding questions! Help please? Vinny-Cent Celica Forum 12 10-31-2005 05:59 PM
Lots of questions about my E153 Transmission (No 56K Plz) JetspeedCamry Camry & Solara Lounge 54 01-21-2005 12:09 AM
D2 coilovers questions aleks77 Camry & Solara Lounge 5 11-17-2004 01:38 PM
A Few Questions zeroscore Yaris, Vitz and Echo Forum 0 08-03-2004 01:11 PM
