Attempting A/C Compressor Rebuild - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2006, 01:36 AM   #1 (permalink)
View aero92's Photo Gallery
Exclamation Attempting A/C Compressor Rebuild
Hi.
I'm trying to find out how to rebuild the original A/C Compressor on my 92 GT 5SFE
It's getting warm here in Tijuana, Mexico.
I saw the O-Ring replacement Kit at Autozone for US $5.00
I believe I'm missing the shaft bearing, but Autozone doesn't display it.
Anyway, is there an online reference where I can go for rebuild info?
I possess a fair amount of skill in regards to Power Steering Pump rebuilds, water pumps, but never an A/C Pump.
Appreciate the help!!!!!
aero92 is offline   Reply With Quote
Old 06-29-2006, 03:04 PM   #2 (permalink)
GA_Wolf's Avatar
View GA_Wolf's Photo Gallery
Gen5
I've seen whole compressors on Ebay going for a reasonable price.
GA_Wolf is offline   Reply With Quote
Old 06-29-2006, 08:13 PM   #3 (permalink)
View toyomoho's Photo Gallery
A bearing supply house might be able to match the bearing if you brought it in.
Old 07-01-2006, 05:30 PM   #4 (permalink)
Thanks for the replires
There's plenty of places here that'll do the job.
But I preferr to do it myself knowing the job was done right.
I just need a quick reference to start and not make a mistake.
One question though.
When I am ready to fill the system, do i need to vaccuum out the air inside or should Icharge the system with Freon then bleed out the air?
I've heard several versions on this and would like to know if for my compressor I could just bleed the air.
thanks!!!
Old 07-02-2006, 09:28 PM   #5 (permalink)
I thought the idea of vacuuming the system was to remove the moisture in the air. I am not sure just filling the system and bleeding it will do this. During A/C operation any moisture will freeze and can cause problems. You can try purging the system with nitrogen gas, this will pick up the moisture.
Old 07-06-2006, 12:03 AM   #6 (permalink)
Thanks, I've got some friends that can do this job, haven't seen them for a long time though, will try to change the bearing this weekend, then week after charge the system up again.
thanks to all!!!
A/C Light Flashes - AC Doesnt work jrock80 Camry & Solara Lounge 24 06-19-2006 12:48 PM
1990 Camry 3S-FE A/C Issue jrock80 1st & 2nd Generation (1983–1986 & 1987-1991) 4 01-20-2006 11:13 AM
87 Camry Wagon A/C Issues!!! Lin 1st & 2nd Generation (1983–1986 & 1987-1991) 3 01-03-2006 06:35 PM
Anyone know about car A/C systems? zarsky99 General Discussion 12 08-05-2003 10:43 PM
