hmm...high idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2006, 10:40 PM   #1 (permalink)
View Platapus75's Photo Gallery
hmm...high idle
Recently bought an auto 1985 Celica GT for $150...the owner said it had tranny issues. Flushed the tranny now it runs great except for the high idle. The only reason it wont pass smog is because it is supposed to be idleing at around 750 and its actually at close to 1550 to 1600. Can ne one help me figure out why or how to turn down the idle. (BTW ive already adjusted the distributor all the way to slow it down as much as possibel) Thanks
Platapus75 is offline   Reply With Quote
Old 06-30-2006, 12:41 AM   #2 (permalink)
RA28 + MX73
View stepho's Photo Gallery
There is an adjustment screw on the carby.
You will find it near where the cable pulls on the pulley which opens the butterfly valve.
It limits how far the butterfly valve can relax back to the closed position (ie no air).Adjust yours so that the buttefly valve closes a little more.
You will probably want to return the dizzy to its original position.
There is also a second screw at teh base of the carby which controls how much fuel is put into the engine at idle.
You probably don't want to change it but if the pulley adjustment above does't work then try the second screw.
If all else fails, go to any mechanic.
This is a 2 minute job if the rest of the engine is healthy.
- Stepho
stepho is offline   Reply With Quote
Old 06-30-2006, 02:43 PM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $220590
View Doctor J's Photo Gallery
I believe the 85 US model is EFI.Therefore:
Check bimetal air by-pass valve, to make sure, it is not stuck open;
Adjust idle to the spec. by turning clockwise the adjusting screw on the top of the throttle body.
For more info refer to Autozone.com repair information.
If, after adjustment, the car will begin to run rough, check vacuum hoses and related items.
Doctor J is offline   Reply With Quote
3VZE high idle LJZTT 89-95 Toyota Pickup/Hilux 2 03-19-2006 07:55 AM
headlights dim when a/c compressor kicks on / high idle kf4zra Camry & Solara Lounge 7 01-12-2005 02:29 AM
1993 V6 high idle... AlphaMale 3rd & 4th Generation (1992–1996 & 1997–2001) 6 01-11-2005 08:00 AM
high idle rpm when cold griptite Hardcore Tech and Competition 5 05-05-2003 02:09 AM
