A couple questions- smoke and audio - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2006, 04:16 PM   #1 (permalink)
Blue Scapegoat's Avatar
View Blue Scapegoat's Photo Gallery
Gen5 A couple questions- smoke and audio
Ok, I bought a '92 Celica GT-S Hatch/Liftback a couple months ago. It's got 110,000 miles on it, runs great, power everything.
Now, I have two seperate curiosities.
For one, it smokes when I start it. If you run the revs up a couple times after starting it, then it will smoke no more until you run it again. I think this is somewhat normal on an older car, but I figured I'd ask some of you that are more familiar with the Celicas. My dad has a '94 Geo Prism that had a toyota engine in it, and it smokes whenever you get heavy on the gas, and eats oil like crazy.
The oil level in my Celica doesn't seem to be falling, so is it possible that this startup smoke is just from a tiny leak, or is it just inevitable, and should I not worry about it?
On to #2- It has the system 10, and I didn't know when I bought it, but the last owner must have had subs in it, as there is wiring under the carpet behind the rear seats. When I play the radio, the sound is good, but when I play CDs I can't even turn the volume up loud enough to hear it over wind and exhaust noise at 60mph, and there is absolutely no bass. Are there some wires I can reattach that maybe he missed if he was messing around with the radio? Here's a pic, and you can see just below the ignition red, white, and blueish-green cut wires protruding. Do these have something to do with it?
Oh, and one more I guess- It has a very large center console, and even though the rest of the interior is mint, the top of the cover is worn quite badly from the previous owner's elbow, I assume. Anybody know where I can get another and/or how much it would cost?
Thanks guys!
Blue Scapegoat is offline   Reply With Quote
Old 07-21-2006, 08:57 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $220590
View Doctor J's Photo Gallery
Smoke emitted for 1 or 2 seconds at start-up usually indicates old exhaust valve seals. To be sure that it is nothing more serious, I would recommend to inspect the spark plug firing ends (they must have no ash or black tar like deposits) and to inspect under valve cover for heavy deposits. If both items are looking normal, just keep an eye on oil level, especially past 2000 mi after the oil change. Use 20W50 oil for summer season or high speed driving.
For console, get an old leather jacket, cut the patch and glue it on.
Doctor J is offline   Reply With Quote
Old 07-21-2006, 04:03 PM   #3 (permalink)
5th Gen Celica man
View ELCelica's Photo Gallery
about the audio, check the amp. it something's wrong with the radio, it would be an internal problem requiring a new radio. at least that's my best guess.
about the console, I went to www.toyotapartscheap.com and found the lid, however, it says that it is for the 2.0L and 2.2L, but my 1993 GT has a different console lid than your 1992 GTS. They show only a diagram of how the parts fit together, not a pic of the item. It's $41, call em and ask about it. mine's vinyl covered not leather covered.
1993 Celica GT Liftback ST184 w/ 2.2L 5S-FE 5 speed stick
Cardomain: http://www.cardomain.com/ride/2501416
ELCelica is offline   Reply With Quote
Double Post, disregard Blue Scapegoat Celica Forum 0 07-20-2006 04:15 PM
