1991 gt4 ABS problem
Hello,
I just bought 1991 Celica GT4(4x4, 2.0 turbo) and found these ABS problems:
- ABS warning light always on (ignition switch on or motor started)
- sometimes ABS suddently "kicks" (on low speed drive)
I try to pull out some error codes(service conector disconnected) and here they are:
11 - open circuit in selenoid relay circuit
32 - front left wheel speed sensor signal malfunction
35 - open circuit in front left or rear right speed sensor
36 - open circuit in front right or rear left speed sensor
I also check wheels sensors(visually)-ok.
Could 11 caused 32, 35 and 36?
