93 A/C retrofit and recharge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2006, 02:04 PM   #1 (permalink)
View Sedito's Photo Gallery
I am about to use a kit I bought to recharge the a/c system in my sister's celica. The kit says to recharge the system with the r134a to 85% of maximum capacity, but I don't know what the maximum capacity is for the car. I checked the owner's manual and the chilton, but neither has any information on it. Does anyone know what the capacity is?
Sedito is offline   Reply With Quote
Old 07-29-2006, 07:12 PM   #2 (permalink)
View toyomoho's Photo Gallery
The capacity for the system when using R12 was 25.4 +/- 1/8 oz.
Old 07-30-2006, 08:46 PM   #3 (permalink)
View jgcox6's Photo Gallery
USA
Please make sure that you flush the system if the compressor failed, and if not make sure to use ester oil, that is what Toyota dealers use. After that make sure that you replace the expansion valve and the drier or you will just be back where you were. Once you did that, make sure to Vacuum down the system for at least 30 minutes, longer is better. Then recharge the system with the R-134 with the dye in it for leak detection. I would go ahead and replace the schrader valve on the high side for sure. It is old enough to fail.
jgcox6 is offline   Reply With Quote
need help with freon recharge toucheesy MR2 Forum 2 07-05-2006 09:53 PM
