Need help with timing belt tdc - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2006, 01:24 AM   #1 (permalink)
View thao's Photo Gallery
I have a 1994 toyota celica st, Auto tran.,
I just replace my timing belt and now my engine is shaking. The TDC is set at zero right now. Is it the correct TDC? Does anyone know where i can find a list of TDC?
thao is offline   Reply With Quote
Old 07-30-2006, 02:27 AM   #2 (permalink)
View toyomoho's Photo Gallery
The timing specs might be on a label in the engine compartment. What engine do you have?
Old 07-30-2006, 04:22 PM   #3 (permalink)
Gameroom cash: $147537
TDC - Top Dead Center is always 0 for Cylinder one. Your ignition timing on the other hand is 10 deg advance. Now you sure you put the timing belt in correctly? With cams and crank line up in a certain way?
Old 07-30-2006, 10:02 PM   #4 (permalink)
Sometimes the EFI engines can be a little shaky until the timing setup is done. You will need to jump the TE1 (or T) and E1 terminals to set the timing.
Old 07-31-2006, 01:30 PM   #5 (permalink)
It was the cam that was off by 180 degree
Old 07-31-2006, 05:52 PM   #6 (permalink)
That would do it.
Old 08-07-2006, 01:32 PM   #7 (permalink)
Doctor J's Avatar
Gameroom cash: $263590
View Doctor J's Photo Gallery
Cam sprocket 180 degrees off would not matter, however, it will be very difficult to align the cam because the aligment hole in the sprocket would be at the buttom.
Doctor J is offline   Reply With Quote
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
91 replaced Water pump& timing belt 3sfe timings off now??? Toyotasrgreat! 1st & 2nd Generation (1983–1986 & 1987-1991) 3 08-24-2005 12:59 PM
Timing Belt Trouble Anti325 Camry & Solara Lounge 15 06-07-2005 05:36 PM
timing belt, setting to TDC BobES300 General Lexus Discussion 6 03-03-2005 06:11 AM
