You need the following from a manual car:
- flywheel
- W55/56/57/58 gearbox and bellhousing from behind a 5M/6M/7M engine
- clutch presure plate and disc
- clutch slave cylinder, hydraulic line, master cylinder
- clutch fork (inside bellhousing)
- pedal brakcet box (about 1 foot wide)
- clutch pedal
- console and boot to match gearstick
The auto has an electrical interlock that only allows starting in N or P.
Join the 2 wires together that hang under the car near the gearbox.
The speedo drive must be matched to you diff ratio.
If the donor car has a different diff ratio then your speedo will be out.
The W55/56/57/58 are interchangeable - just the ratios differed.
The W55/etc from any Toyota of the period will work.
The bellhosuing must come from a M series engine (5/6/7M) that had a W55/56/57/58 gearbox (ie bellhousing and gearbox can come from different cars).
In practice, this means a bellhousing from a Cressida, Crown or Supra from the mid 80's.
The older W50 (1970 to 1981) is not interchangeble with these.
- Stepho
