90' Celica Turbo Swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2006, 02:13 PM   #1 (permalink)
View Mondo131's Photo Gallery
I just purchased a 1990 Celica GT and am wondering if the factory turbo installed on the other Celicas will just bolt right in.
With the intercooler built into the hood (or so im told) Will the hold bolt right in-place of the old one?
I know what parts i'll need to grab just want to know if it is a direct replacement of what is already there.
Mondo131 is offline   Reply With Quote
Old 08-07-2006, 04:01 PM   #2 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
it'll bolt right in but the intercooler wont fit cause the intake manifold is different, so you'll have to find a different way to put install the intercooler.
89CelicaGTTurbo is offline   Reply With Quote
Old 08-09-2006, 11:02 AM   #3 (permalink)
Will the hood fit? (The one with the scoop) so the intercooler goes underneath the hood and will hit the manifold.
So bassicly i can jus tput the intercooler on the front and everything will work fine?
Old 08-09-2006, 12:14 PM   #4 (permalink)
Gameroom cash: $147537
The Top mount Intercooler is bolt on the the valve cover. You need a hole in the hood to fit. Unless you get the 3S-GTE with water to air intercooler then you can use stock hood with it. You can't use the top mount in the front. You'll need aftermarket front mount IC.
Old 08-10-2006, 11:44 AM   #5 (permalink)
But what if i get the Hood with the scoop, will the intercooler be in the same place on my GT as to fit into the hole in the hood?
Old 08-10-2006, 07:15 PM   #6 (permalink)
Always Bored
View hachi-rocu's Photo Gallery
I think right now you should search around for more information regarding what motor you will be using. You can use any 3sgte motor or make a turbo 5sfe. All of these choices have different budgets and parts needed.
I have never done it for the money.......except for that one time
hachi-rocu is offline   Reply With Quote
Old 08-20-2006, 08:27 PM   #7 (permalink)
Know any good websites?
Old 08-20-2006, 08:39 PM   #8 (permalink)
That intercooler ONLY works with 3S-GTE engine. You can't use it on a 5S-FE.
Old 08-22-2006, 05:10 PM   #9 (permalink)
Boooost
turbo_GT's Avatar
View turbo_GT's Photo Gallery
The air to air tmic will fit under the stock hood without a problem....only thing is his car will suffer heat soak...
Your signature is in violation of rule #4.
http://www.toyotanation.com/forum/t20118.html
turbo_GT is offline   Reply With Quote
Old 08-22-2006, 05:24 PM   #10 (permalink)
Top mount air to air IC under a close hood ..... what's the point? Hot air-hot air interwarmer?
It works for like 5 min?
Selling 90 GT-4 Celica celicast185 Vehicles 6 08-29-2005 02:33 PM
90 celica 3sgte swap coolredleg Celica Forum 2 10-08-2004 10:24 PM
FS: 1988 celica turbo st-165 ontario TurboEh Vehicles 2 09-15-2004 09:56 AM
Celica GT turbo kits SFpower Celica Forum 5 12-05-2003 02:54 AM
Celica or Camry Swap, need Some votes please ! TruBtc Celica Forum 4 08-28-2002 02:25 PM
