Hot Key Ignition or sun? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2006, 12:21 PM   #1 (permalink)
View pixelpadre's Photo Gallery
I have noticed my key is too hot to touch on occasion when I pull it from the ignition. Is it the sun or something else. 89 Celica. Also, I need new exhaust. Catty is cast iron on block. Anything wrong with replacing OEM with regular pipe after cat converter?
pixelpadre is offline   Reply With Quote
Old 08-15-2006, 10:44 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $263590
View Doctor J's Photo Gallery
If the ignition switch gets hot, the heat will be also sensed on the opposite side of steering column, where it is actually located.
Doctor J is offline   Reply With Quote
Old 08-26-2006, 09:32 AM   #3 (permalink)
USA 89 Celica Ignition switch is hot
Ok I bought the new switch, but I can't see how the cowling comes off. My eyes aren't that good. Does anyone know how many screws and what kind of screws. I saw a bunch of holes but no screws.
1989 Celica ST
Old 08-26-2006, 03:33 PM   #4 (permalink)
1987 Celica GTS
Noobified's Avatar
View Noobified's Photo Gallery
Im not sure about the ignition problem, but a new exhaust at a shop will work the same if not better than OEM! you can do a cat-back system for a few hundred. Get stainless steel, it might weigh a lil (not a lot ok.. its not much piping) but then you wont have to deal with rust for a long while, if not the rest of the cars life. I have NO rust on mine after 2.5 years. 2.5" cat-back on my mazda protege. You sound like your an older fellow, so I dont think you want a loud exhaust, so get a nice muffler (lil bigger than stock, allow more flow, meaner growl) and put somthing slightly larger than whats on the car now. Like 2.25" or 2" seems to be common.
Noobified is offline   Reply With Quote
Old 09-11-2006, 08:25 AM   #5 (permalink)
I put a new ignition switch in because someone told me that a hot KEY is a sign of a bad ignition switch. well...the new ignition switch was never attached to the steering column yet and the key still gets hot from the sun and ambient temps inside the car. I have to put the key in the cylinder in order to unlock the steering wheel.
1989 Celica St
Realtor
Elec engineer
www.lakecountyclassifiedads.com
Key broke in ignition of 1990 corolla. applesandwich 6th Generation (1988-1992) 3 06-06-2008 01:31 PM
key stuck in ignition bisbeek 1st Generation (1998-2003) 1 08-11-2006 01:40 AM
Fresh Wax + So Cal Sun = Hot knotquiteawake Camry & Solara Lounge 9 05-22-2006 05:22 PM
Ignition key is stuck... annipants General Discussion 14 03-17-2005 09:23 AM
