Wont rev past 5000 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2006, 07:11 PM   #1 (permalink)
View reeper's Photo Gallery
Exclamation Wont rev past 5000
Hey
A friend is having a problem with his 92 gt. The Thing wont rev past 5000 We already know it needs a new clutch but we dont think thats the problem. I almost seems like its hitting a rev limiter or somthing. Cloged fuel filter?
Just wondering if you guys had any ideas
reeper is offline   Reply With Quote
Old 08-25-2006, 08:19 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142720
View mazdaverx7's Photo Gallery
wont rev past 5K at idle or while driving? check you basic essentials, plugs, wires, cap, rotor, fuel filter, air filter, etc. after that, check the timing and check for any vaccume leaks. inspect the converter condition, making sure you are getting good exhaust flow from the muffler. start there.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-28-2006, 04:13 PM   #3 (permalink)
1987 Celica GTS
Noobified's Avatar
View Noobified's Photo Gallery
Check the intake too if you have a cold air intake. Look for water settled in the bottom. To get water out of the cylinders, pull one of the plugs out, and crank the car (with the cap unplugged) for short intervals, dont crank excessivly.
Noobified is offline   Reply With Quote
Old 08-30-2006, 11:17 PM   #4 (permalink)
View sameerb1's Photo Gallery
i had the same exect problem and found out it was due to the exhaust menifold had a crack in it. so check the exhaust also!
sameerb1 is offline   Reply With Quote
Old 09-10-2006, 07:02 PM   #5 (permalink)
View celeritas's Photo Gallery
hmm ....no check engine light? ...ide take off the battery over night ...let everything reset ...it might be a problem of that sort ...just guessing
celeritas is offline   Reply With Quote
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Car problems, dog'n down/hesitates and wont rev past 4k DLo Camry & Solara Lounge 8 03-07-2006 01:28 PM
FS: Nikon WC-E63 x0.63 Wide-angle lens for Coolpix 4300, 4500, 5000, 8400, 700, 775 EKam Non-Automotive 0 02-19-2006 10:35 AM
Now this is OFF TOPIC modifierLE Off Topic 14 09-06-2005 08:49 PM
