exhaust raddle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2006, 01:13 PM   #1 (permalink)
View stage3celi's Photo Gallery
Gen5 exhaust raddle
when ever im in reverse or im shifting gear (which i have to to really soft or something raddles) i hear something raddle. i took it to a shop and they told me it was my exhaust which i think it is because it doesnt drive any diff. everything feels the exact same. i took it to the muffler shop that i got my exhaust done and they only checked the part that they did(cat back) when it sounds more like its comeing more by the manifold, has ne one had this problem or know were exactaly its comeing from?
stage3celi is offline   Reply With Quote
Old 08-26-2006, 01:37 PM   #2 (permalink)
someone have any ideas?
Old 08-26-2006, 03:38 PM   #3 (permalink)
1987 Celica GTS
Noobified's Avatar
View Noobified's Photo Gallery
I've had radles coming from my car before. First, check your wheel well and make sure the bold that holds the wheel down is tight, and is holding the wheel down! and make sure the jack and crap is secure. Take it out and drive it, if the noise stops, thats your problem, if not, keep looking. Lic plate seems to do it too. make sure its secure. Just look! It could be loose bolts that connect to the converter, but I doubt it, but its cant hurt to check all the exhaust bolts. I think your car is resonating very loud and the reverbs are vibrating the shit out of somthing. Its not serious, but its annoying!
good luck.
Noobified is offline   Reply With Quote
Old 08-26-2006, 05:02 PM   #4 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
I took off my heat shields from under the car that was my rattle.
thousand_five is offline   Reply With Quote
Old 08-26-2006, 11:08 PM   #5 (permalink)
Gen5
it does it when i turn my car on and off so it would have nothing to do with my wheel and i have no cat so its not that what else could it be? whats a lic?
Old 08-28-2006, 03:25 AM   #6 (permalink)
1987 Celica GTS
Noobified's Avatar
I meant lic=license plate sorry.
Old 08-28-2006, 07:04 AM   #7 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
Would be one of the first things I 'd check - have had loose heat shields on a few cars, 'tis most annoying !!! Dunno if I'd recommend taking them off, as the manufacturer put them there for a reason. Tightening them up would be prudent
PhantomS is offline   Reply With Quote
Old 08-28-2006, 12:34 PM   #8 (permalink)
I still have the heat shield by the gas tank
Old 09-02-2006, 12:02 AM   #9 (permalink)
so you think its my manifold heat sheild is lose
Old 09-02-2006, 01:29 AM   #10 (permalink)
Gen5
There is a posibility. My exhaust manifold cover has a snapped bolt on it. and it vibrates also. What I think your rattle is....... it could very well be something along the exhaust piping. could be the following:
Heat shields.....
Loose exhaust clamp.......
Exhaust banging agianst the side of something.
best way to check is to put car in first gear and clutch down put emergency brake on..... then look under your car while your clutch is down and in first gear while the engine is runing and run a good 2000 rpms and pop the clutch to where it starts to grap then quickly release it. that will cause the exhaust to shake violently.
Good luck!
Old 09-02-2006, 11:53 PM   #11 (permalink)
you do think it could be my manifold do you
Old 09-03-2006, 12:07 AM   #12 (permalink)
have you tried the test yet?
The exhaust on my 4A-F is just rediculous Elizle Archived Corolla threads 21 08-30-2006 12:48 PM
exhaust raddle stage3celi Celica Forum 0 08-25-2006 01:13 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
custom exhaust/ intake slipknot490 1st Generation (2003-2008) 1 10-05-2004 02:37 PM
