Originally Posted by iseeu2
I have a '90 celica and I was wondering if anybody knew what I could do to increase the low end pick-up...From the first gear through pretty much the 4th...actually till i hit about 60 or 70 mph the pick-up laggs horribly...don't even mention hills too! It seems like I have to ride the clutch for a while to get it to even pick up at all when I'm shifting gears or the lagging is just unbearable. I can press the gas pedal to the floor and leave it there for 30 seconds and it won't speed up any faster.
Sounds like it may be the clutch. Go about 40-50mph or where ever you can get into 5th gear at about 2-3000 rpm and put the gas pedal to the floor. Watch the RPM's, if they climb (get higher) and the cars speed (mph/kmph) stays the same, you have a worn out clutch, Its slipping. It makes sense that might be the problem, because at about 60-70mph, the engine cant load the transmission as baddly (lack of power) as when its stopped/in lower gears, making it so it seems laggy at slow speeds, but ok in the higher speeds.
Good luck!
