st162 sleepy lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2006, 07:39 AM   #1 (permalink)
View hatharry's Photo Gallery
4th Generation st162 sleepy lights
does anyone no how no how i can make my lights go sleepy (half way up)
hatharry is offline   Reply With Quote
Old 08-28-2006, 12:28 PM   #2 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
Dunno if it works the same on gen4's, but on my 5thg, I can stop them partially down by perfectly timing the turning off and then back on of the headlights.....you turn them full on immediately after turning them full off, as the motor starts to retract them and it'll stop down a little bit...do that a couple times in a row 'til they're as low as you want. Took me about 20 minutes to figure the "timing" of it, but it works pretty consistently, now. As long as you don't turn the switch to full off (the "first off" position/lights up position) after lowering, the lights'll stay there, and can be turned on and off at the chosen sleepiness. Turn it to full off and lights return to normal operation, easy as that I kind of like the look now and again, and I even like better not spending $$$ on a switch/controller/whatever. Hope that helps
PhantomS is offline   Reply With Quote
Old 08-28-2006, 04:03 PM   #3 (permalink)
1987 Celica GTS
Noobified's Avatar
View Noobified's Photo Gallery
Yes, its easy. Pop the hood and next to each light are cylinder things. Each should have a cap on them, take the cap off, and twist them until you get the desired level of "sleepieness" for each light.
Noobified is offline   Reply With Quote
My bed Lights and Backup lights Pb 2nd Generation (2005+) 104 02-24-2011 05:35 AM
How anyone can change the traffic lights green Misctick Off Topic 35 06-06-2006 10:45 AM
Instrument Panel Lights Not Workin goderaj 4Runner Lounge 0 01-26-2006 10:28 PM
gen 3 auto turn off lights MrSo0h0o 3rd & 4th Generation (1992–1996 & 1997–2001) 17 11-12-2005 11:21 PM
Lights Lights Lights Seiwoong Archived Corolla threads 0 08-24-2005 11:54 PM
