not stable on idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2006, 11:22 PM   #1 (permalink)
View sameerb1's Photo Gallery
not stable on idle
I have my repairs done on the engine of my st185(3sgte)(head gaskit changed, head ported and polished, injectors cleaned, piston rings changed, piston bearings changed, crank bearings changed, camshaft bearings changed, exhuast menifold repaird etc.), the car runs smooth. the gears shift nicely. no sound of anykind is heard. the only problem is on idle my car is not stable. it revs for itself (between .8k to 2k in rpm meter while on idle). the spark plugs are new. some electricians told me it could be the idle sensor. anyone can help me with this problem?
sameerb1 is offline   Reply With Quote
Old 09-05-2006, 04:37 AM   #2 (permalink)
no one can help me out here?
Old 09-05-2006, 06:25 PM   #3 (permalink)
View toyomoho's Photo Gallery
What year and specific model is this car?
Old 09-06-2006, 05:36 AM   #4 (permalink)
its a 1991 st185 swaped to 3sgte engine
Old 09-06-2006, 06:22 PM   #5 (permalink)
Not up on engine swaps, but. Normally engine idle control is added by the air idle control valve. If the engine speed is hunting and this was a stock engine, would say to start here plus look at the MAP sensor. How did you handle the change in idle air control valve, EGR, MAP and throttle position sensor hookups? The hookups between engines appear to be different. The link below has some info on this swap.
http://www.toyotacelicaonline.com/celica1/3sgteswap.htm
Also check this thread that has started on this swap plus past posts.
http://www.toyotanation.com/forum/t77578.html
Rough idle cozmo_im 6th Generation (1988-1992) 2 11-05-2008 12:29 AM
Is the idle speed of V6 (3VZ-E) adjustable? hydrogenh2 89-95 Toyota Pickup/Hilux 1 06-20-2006 12:57 AM
99 4-cyl idle air valve removal sixto Camry & Solara Lounge 3 02-18-2006 01:16 PM
Low Idle when cold and when AC is on Tom Simon Hardcore Tech and Competition 3 04-02-2005 03:04 AM
No Idle after motor rebuild wrenchdad MR2 Forum 0 01-09-2005 08:19 AM
