fuel pump runs continuously - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2006, 08:57 AM   #1 (permalink)
View pixelpadre's Photo Gallery
Hey, when I turn on the ignition key, I can hear the pump running....but it doesn't seem to shut off. The first few seconds the tone is a low hum, then it switches to a higher pitched hum.
any thoughts.
thanks
pixelpadre is offline   Reply With Quote
Old 09-07-2006, 01:09 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $263390
View Doctor J's Photo Gallery
Need info. on year of your Celica?
Doctor J is offline   Reply With Quote
Old 09-07-2006, 01:12 PM   #3 (permalink)
89 celica st
Old 09-07-2006, 03:45 PM   #4 (permalink)
Doctor J's Avatar
On this car the fuel pump is controlled by two coil circuit opening relay near engine ECU. Remove it and check for broken spring/ fused together main contacts. If relay is OK, unplug the pump and attach test light instead. Turn ign. on. If light is ON, remove connector from the air flow meter. If light goes out, check /repair air flow meter. If light still on, there is a short to the ground on the wire that goes from the relay to the air flow meter.
Old 09-07-2006, 03:55 PM   #5 (permalink)
Not following you on the description of broken spring/fuse relay. Not sure what that is or how to check it. Simple fuse I can do but spring/fuse relay is something im not familiar with.
thanks for the other advice though. Sounds good.
steve
1989 Celica St
Realtor
Elec engineer
www.lakecountyclassifiedads.com
Old 09-07-2006, 05:36 PM   #6 (permalink)
View toyomoho's Photo Gallery
Fuel pump power is controlled by a relay and this relay may be defective. You need to pull the relay and test it. Or the air flow meter may have a problem, telling the fuel pump system the engine is running when it is not. If the pump stops working when the wire to the air flow meter is removed, this part could have problem. Or there could be grounded short in the wiring between the meter and relay.
Old 09-10-2006, 07:00 PM   #7 (permalink)
View celeritas's Photo Gallery
ide check the relay also ...just test it with a dvm
celeritas is offline   Reply With Quote
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
85 Celica GTS Fuel Pressure Problem Denis Celica Forum 6 03-16-2006 08:11 PM
