a/c stuff - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2006, 01:55 AM   #1 (permalink)
View plainsmen86's Photo Gallery
USA a/c stuff
when i turn the a/c the engine doesnt go to higher rpms it bogs down and shakes the car ... wut do i do
plainsmen86 is offline   Reply With Quote
Old 09-09-2006, 02:05 AM   #2 (permalink)
View toyomoho's Photo Gallery
What year of car?
Old 09-09-2006, 04:39 PM   #3 (permalink)
86 engine is a 2selc 2.0 gt
Old 09-09-2006, 07:48 PM   #4 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
It's a, uhhh...what ???
PhantomS is offline   Reply With Quote
Old 09-09-2006, 09:19 PM   #5 (permalink)
Just guessing here. When you turn on the A/C, an idle up solenoid is energized. This seems to control the idle air control valve, kicking up the idle. The solenoid may be defective or the A/C amplifier (if it has one). The air control valve system appears to use vacuum hoses, check for leaks or damaged hoses. The idle up solenoid might be in the engine compartment, look for something with vacuum hoses and 12v wires going to it.
Old 09-09-2006, 10:04 PM   #6 (permalink)
thanks yeah ill check that out you can use a smoke machine right?
Old 09-10-2006, 12:13 AM   #7 (permalink)
Not sure what you are referring to on the smoke machine. Are you trying to see if the leak draws in the smoke? Some folks use a flammable gas such as propane (small propane torch). The idle will pick up when the gas is ingested. Guessing the 12V DC solenoid has problems, does not turn on, stuck, etc.
Old 09-10-2006, 08:18 PM   #8 (permalink)
4th Generation
the smoke machine produces smoke and you put into one of your inlets and start the car and if theres a leak smoke will come out ... but anyway yeah ill try the propane thing, and where would the solenoid be located?
Old 09-10-2006, 08:35 PM   #9 (permalink)
Just guessing it might be bolted to the firewire, engine side. Look for a hose running to the air idle control module. This is just a guess.
Old 09-10-2006, 08:42 PM   #10 (permalink)
allright thanks
Diagnose/fix my A/C low00ranger 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-14-2006 11:38 PM
A/C Not blowing Cold Air garrand3006 Archived Corolla threads 4 08-09-2006 04:08 PM
Heat and A/C? dpenz 2nd Generation (2000-2004) 5 08-07-2006 06:38 PM
A/C Help biggieeb0y Camry & Solara Lounge 0 05-29-2006 05:26 PM
A/C constantly on - 96 Tercel Esox Tercel, Paseo, Starlet, and Sera Forum 1 08-09-2004 09:20 AM
