OK...89 Celica refuses to start sometimes (won't even crank), mostly when hot.
New:
- starter
- alternator
- battery
- starter multipurpose relay under glove box
- ignition switch
When it does start...the dash voltmeter dips only 2 volts.
When it doesn't start...the dash
voltmeter goes to zero while igntion switch is on.
Symptons did not change after replacing all of the above named parts.
Battery terminals and wires all cleaned.
I am truly puzzled.
How about bearings? Could this be a non electrical problem?
