Oops, forgot to mention something.
The Supra has IRS and rear disc brakes.
Disc brakes means you need to use the correct brake bias valve (drums elf servo, so they only need a little bit of pressure, discs needs lots of pressure).
The IRS can be fitted by measuring the 4 bolt holes in the chasis where the IRS K-frame bolts in.
Drill these in your chassis.
Accuracy is important.
Be real careful of aliging the bolt holes or you will steer crooked.
Cut off the panhard rod mount.
Attach K-frame.
Sounds harder than it is
Also, the RA65 Celica LB and Manual Coupe have the same rear end as the Supra.
Here's a list of diffs from other Toyota cars.
http://ourworld.compuserve.com/homep...tepho/diff.htm
(towards the end).
If all this sounds too complicated, then look at a MA4# Supra rear end.
It's a solid axle instead of IRS but has an F series diff.
I'm not certain but I think the suspension mounts are in the same place as your car (4# and 6# have pretty much the same rear chassis frame rails).
Still have the hassle of converting to rear disc.
- Stepho
