which swap for '73 Celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2006, 01:33 PM   #1 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
Hello, I was wondering which swap would be better for my '73 Celica.
80–84 / 22R
or
85–90 / 22RE
What would be the Pros and Cons of each?
TheKevin is offline   Reply With Quote
Old 09-11-2006, 02:57 PM   #2 (permalink)
View Saggz's Photo Gallery
22R would be easier because its carb'd. 22RE would be better for drivability and performance, probably gas mileage too, downside is that you would need to swap out your fuel system for high pressure lines, electric pump and of course all the wiring to run the motor. If you were to use a simple standalone like MegaSquirt n Spark or something, it would be pretty straight forward.
If you can find a 2/3TC, 22RTE or an 18RG, that would be sweet...
Saggz is offline   Reply With Quote
Old 09-11-2006, 11:14 PM   #3 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
I agree with Saggz.
Some more info:
You will need a '75 RA22 crossmember or modify your RA21 crossmember so that the taller 22R or 22R-E block will fit in the engine bay.
The 22R and 22R-E are essentially the same block and both will happily bolt up to your W50 gearbox.
Since you are choosing blocks, look at the following page and select bits to build a hybrid engine with 22R block and 20R head.
http://ourworld.compuserve.com/homep...pho/eng20r.htm
http://ourworld.compuserve.com/homep...pho/celfaq.txt
- Stepho
stepho is offline   Reply With Quote
HELP!! What differential will swap in my 85 Celica?? toyloco Celica Forum 5 02-18-2006 11:35 PM
camry v6 trans into 90 celica (3sgte swap). sbettencourt Introduce Yourself Here 1 01-08-2006 10:32 PM
90 celica 5sfe to 3sgte swap 90_celica Celica Forum 16 02-08-2005 07:19 PM
Celica or Camry Swap, need Some votes please ! TruBtc Celica Forum 4 08-28-2002 02:25 PM
Celica or Camry Swap, need Some votes please ! TruBtc Camry & Solara Lounge 4 08-20-2002 02:53 AM
