Lifters - help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2006, 12:18 PM   #1 (permalink)
View kerwinq's Photo Gallery
Lifters - help
What is the down side to re-using lifters in a rebuild? I took the lifters out not intending to use them again so did not mark which lobe they came from, now am looking at getting new ones and the price is more than I expected.
The head was reworked but nothing was done to the cams
Thanks, Kerwin
91 Celica GT-S
2.2
kerwinq is offline   Reply With Quote
Old 09-16-2006, 05:13 PM   #2 (permalink)
View toyomoho's Photo Gallery
On this engine, do the cams ride directly on the lifers and shims? If so, reusing the lifters should not be problem. Provided you readjust if required, the valve clearance.
It is possible the shim may have worn in with the lifter, but the shims are pretty hard. I have not heard of problems with swapping shims or installing new ones when adjusting the clearance. Still, you might check for shim surface wear. Or just turn them all over to present a new side to the cam.
Old 09-16-2006, 07:51 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
let the machine shop set the head up
GDMF Lifters and POS shims! pee_cup 89-95 Toyota Pickup/Hilux 2 09-15-2006 03:21 PM
1zz lifters in 1mz? chronoti Camry & Solara Lounge 1 11-09-2005 12:25 PM
cheap lifters? chronoti Archived Corolla threads 1 11-06-2005 07:40 PM
engine runs noisy..could it be lifters??? lifeisviewtiful Archived Corolla threads 2 06-11-2005 11:10 AM
