brake problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2006, 02:26 PM   #1 (permalink)
View celica91's Photo Gallery
brake problem
the brake pedal on my 91 celica will go almost to the floor, but when i release it and press it again, its goes back to normal. If I wait a minute the pedal will go to the floor again. I just had the rear pads replaced a week ago and the mechanic didn't adjust the one side correctly, so you can smell the hot brakes and feel the heat coming from that wheel, and that wheel alone. Not sure if that has anything to do it, but the pedal to the floor problem just started today. any thoughts?
update: fluid level ok. took it for a spin around the block, brakes worked perfectly. coudl an overheaded rear drum brake cause the above symptoms?
celica91 is offline   Reply With Quote
Old 09-17-2006, 05:56 PM   #2 (permalink)
gts-rated
xrated3345's Avatar
View xrated3345's Photo Gallery
bleed the brakes it needs to build up presssure thats why you step on it the second time its ok. ps its always good to check hoses just incase and worst case calipers.
http://www.myspace.com/13833694
xrated3345 is offline   Reply With Quote
Old 10-27-2006, 07:53 PM   #3 (permalink)
View itschuck2c's Photo Gallery
No its your master cylinder..replace it
itschuck2c is offline   Reply With Quote
Old 10-27-2006, 09:09 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
master is history
Old 10-28-2006, 02:30 AM   #5 (permalink)
View gervis01's Photo Gallery
Yep the master cylinder could be bad and needs to be replaced. If your brake fluid is very low then you should also inspect the cylinder fluid level and fill to the appropriate level. Another possible culprit is that there's an air or leak in the hydraulic system, so you should bleed it or remedy the leak if there's any. Good luck with your brake issue.
gervis01 is offline   Reply With Quote
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
2001 soft brake pedal problem Lunar Mist 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-14-2006 09:48 PM
Brake and Tranny Problem fastwrx 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-01-2006 06:33 PM
1991 Pickup Front Brake Problem HELP?? beanj 89-95 Toyota Pickup/Hilux 4 04-06-2006 11:06 AM
Brake Problem Help!!!!! tskelton1211 Camry & Solara Lounge 18 12-10-2004 12:09 AM
